This is starting to get frustrating now.
I used to use forty-two (I think it was version 1.5.2) and it worked beautifully. Well after a complete system reinstall I installed forty-two 1.6. I put the application in my applications folder. I ran the installer script. Forty-Two will decode and convert the files. But whenever it tries to multiplex the files I just get an empty burnwhatsinhere folder.
Its become quite an annoyance. I always have the files put in a folder in which the entire destination has no spaces in it. I don't know what else to look for.If anyone would have some advice it would be much appreciated.
Where you online when you installed it? As far as I recall you need to be.
Yeah, I have broadband. Again everything encodes properly. It just does not put them together and split the file so it fits on one cd per file.
The same thing is happening on my other computer. I don't get what the problem is? -
Try updating to 1.6.2' admittedly I haven't used this app in a while, I use 42DVDMP quite a bit though....
The future is tomorrow!
The Film Machine Problem... MULTIPLEXING FREEZE
By supermannnnn in forum Video ConversionReplies: 3Last Post: 16th Dec 2012, 11:51 -
Multiplexing Multiplex files?
By mrjust in forum Newbie / General discussionsReplies: 5Last Post: 3rd Dec 2012, 23:54 -
.264 + AC3 Multiplexing problem
By 557953 in forum EditingReplies: 4Last Post: 24th May 2011, 09:16 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 15:52 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 10:13
