    Feb 2004
    Canada
    Well i just recently downloaded an .avi and tryed to run it through tmpgenc but the video freezes about 10 seconds into the video and all i get is an hour and a half long picture . Ive tryed it in a mpegmaker and a windows error came up saying it would have to restart the program. So i tryed the bad fram scan on virtualdubmod and it didnt say there were anybad frames so i am at a TOTAL loss as to what to try next.....So if anyone out there can help me it would be much apreciated and if u need more info just ask THANKS!
    Apr 2002
    Oskeeweewee Ontario
    Did you scan for bad frames within Virtualdub, or VdubMP3Freeze???
    Feb 2004
    Canada
    Yeah i did it with virtual dub mod and it just said 0 badframes/0goodframes whatever that means
  4. Does it play? If not it could just be a bad download. Also there are tools int the tools section that will tell you what kind of avi it is and what you need to watch it.
    Dec 2002
    My Swamp
    I think it is better to use virtualdub mp3 freeze to scan for bad frames.
    Also make sure the direct show multimedia filter is set to2 if you haven't already done so . Check HERE to see how.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That's a downloaded AVI for ya! 9 out of 10 I've got from KaZaA (long since now...) suffered from one error or another. Not worth the trouble.
    /Mats
