  1. I was wondering how to create a DVD-A using the ac3 or DTS soundtrack from a DVD.
    Is it possible? Anyone know how?
    you can try discwelder bronze. trial available.
  3. No luck that route. I'd be good If I could just find a way to convert a dts file to 6 wave files, like: lf.wav, rf.wav, c.wav, rs.wav, ls.wav, lfe.wav
    Any Ideas on that? I've been playing with besweet and azidts, but it just fails with an error.
  4. WEEEEEE!!!!!
    Looks Like I got it. After trying everything, I tried HyperCube. I seemed on the right track & eventually figured out to use dtssource.ax and install it properly by putting in system32 and running regsvr32 DTSSource.ax.
    Now Hypercube is splitting the .dts file into 6 wav files. Looks like it will take a while, but so far, so good.
    I'll post the results for anyone else that may need help.
