I am looking for some professional software recommendations to encode wedding video for dvds.
I also would like recommendations for authoring software. I currently edit with Adobe Premiere 6. Anyone out there that does weddings as a profession please feel free to contribute. Thanks
You want to edit or just encode??? You said just encode...I asume you want to edit them too...
Basically Premire will work fine...The easyest way to make it work is to use uncompressed avi files...if you have the hard drive space...Do you?? A better program is Avid Express Pro, but it is expensive...
What kind of editing do you want to do?? Simple cut and join, or more bold stuff like zomming and neat transitions...?? need more info... -
ok, I am sorry I read you wrong...for encoding I recommend TMGenc, but really for DVD it does not matter to much, if you want the standard two hours in one 4.3GB DVD. Never use the encoding in Premire...it is crap.
What kind of editing do you want to use?? -
what makes editing a wedding video different from any other video?
if you're looking for specialized transitions, frames, graphics, etc, check out DigitalJuice, I think they have some video & graphics stuff aimed at wedding videos. pricey, though.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
I want to know what software other professionals that do weddings use to get an idea of what outputs good quality. I want to do weddings and make some money at it, hopefully. I would like to be able to put out decent work. I currently have TmpGenc plus and TmpGenc dvd author. I was looking for other maybe faster encoding times and more to work with than dvd author. Do you guys do wedding videos professionly? I use avi and wave files and do my editing with Adobe Premiere. I just want to hear what others are using.
Yes, there are more professional programs to use...for example, Avid Express Pro is hands down better than Premire...
As for encoding, if you are looking for speed, CCE is probably the fastest, but TMGenc is great. but you must use avisynth with CCE.
So, set it up like this...
avi >> Premire/Avid >> avisynth (frameserve) >> CCE -
I am a wedding videographer also and I use Premiere. It seems that most of the people I talk with in this industry love Vegas and more WV'ers use it than most other proggies combined.
I use Premiere simply because its what Im used to.
sp -
Sellpipe,
What do you encode with? what do you author with? Poerschr thanks for your input.
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
