Andyp1 (a helpful chap) recommended that I get virtualdub MP3 freeze to check my AVI files for bad frames. The link in the tools section takes me to a site that only has virtualdub on it...can anyone post the correct link for me please? At the moment I have Virtualdub mpeg2 1.5.10 - Is this the right one. I am trying to extract the audio which is MP3 so I can convert it to AC3 (as per Andy's instructions) although I'm not really sure why I am doing this - is it because if I compress the audio, I can then set a higher bitrate for the video when I encode it to Mpeg2?
God this is hard!
There are lots of people here and guides who/which are very helpful - but I find that they tell you how to do a task but rarely why you need to do it, or what benefit it would bring.
Appreciate any answers.
Go back to your link and scroll down to find all the Virtual Dub versions.Originally Posted by KeithchrHello.
http://www.digital-digest.com/dvd/downloads/virtualdub.html
Scroll down this page and you will find it.
It has all the virtualdubs on that page.
I use virtualdub mp3 freeze to check for bad frames
I use virtualdub to extract the audio to wav when it is mp3
I use virtualdubmod to demux ac3 if the original file has ac3 audio
I have virtualdub mpeg2 , I have used it but I can't just remember what I used it for now .
Different versions seem to perform a different function particularly well for me.
They are only small programmes so no harm in having them all on board.
Don't forget ffmpeggui for converting to ac3.
This is about the best guide to follow
https://www.videohelp.com/forum/userguides/186739.php
Have fun
Keithchr,if you did a search for audio problems (with tmpgenc i assume)then you would know why its better to extract the audio,people here give help but they cant tell you everything you need to know cause they cant read your mind.
Difficulty sending videos to Iphone.
By hellfire45 in forum Video ConversionReplies: 2Last Post: 2nd Jan 2012, 03:58 -
MKV Conversion Difficulty
By thatmantisguy in forum Video ConversionReplies: 6Last Post: 5th Mar 2010, 17:04 -
Difficulty Accessing Video Help
By usually_quiet in forum FeedbackReplies: 7Last Post: 14th Apr 2008, 18:11 -
question about difficulty in uninstalling file
By jimdagys in forum ComputerReplies: 3Last Post: 28th Mar 2008, 10:52 -
Rare Decryption Difficulty
By Big C in forum DVD RippingReplies: 2Last Post: 8th Sep 2007, 11:24
