I've alredy read the thread on TMPGENC tips and it said to set the directshow multimedia file reader to 2. It was at 3 by default while I experienced the problem. So I set it to 2, samething. The problem is whenever I load the movie and click start, it just freezes up and then says it has to shutdown. Before my pc crashed, I was able to convert Xvid videos no problem. I can convert DIVX and other avi files, just not xvid. I have the neccessary codecs installed. I can play the movie in WMP just fine. I can even convert with Allvideoconverter; I just can't with TMPGENC now.
Here is the info on the xvid movie
Yet Another Avi Info (YAAI) Output File
visit http://yaai.sourceforge.net/ for more information
AVI Information
Filename: xvid-disc1.avi
Filesize: 733530112 Bytes (699.55 MB)
Streams (i.e. Video, Audio): 2
Video Stream
Compression: xvid - XVID MPEG-4
Avg. Bitrate: 1258.43 kbit/s
Resolution: 576x304
Color Depth: 12 bits
Running Time: 3420.09 s (57m 0s)
Framerate: 23.9760 fps
Microseconds Per Frame: 41708 ms
Frames: 82000
Keyframes: 605 (Every 135)
Audio Stream
Wave Type: 8192 - AC3 Audio
Avg. Bitrate: 448.00 kbit/s
Sample Rate: 48000 Hz
Bit Depth: 0 Bits
Channels: 5
Audio Delay: 0.00 s
Author Details
Artist:
Comment:
Copyright:
Name:
Product:
Source:
Subject:
Display Name:
Here is the environment settings of TMPGENC
VFAPI-Plugin Property
Directshow Multimedia file reader 3
AVI2 file reader 1
AVI VFW compatibility reader 0
Cyberlink- MPEG-2 Decoder 0
Microsoft- MPEG-I Decoder 0
Wave file reader 0
BMP\PPM\TGA\JPG file reader -2
try scanning the avi for bad frames using virtualdub.
you could also try uninstalling/reinstalling tmpgenc. -
It has ac3 audio so you should just encode the video and bring in the audio in the authoring stage.
In my post, I stated that it freezes when I click start. Doesn't matter what part (Audio or Video) of the movie I try to convertIt has ac3 audio so you should just encode the video and bring in the audio in the authoring stage.
Its unlikely to freeze before you hit start is it.In my post, I stated that it freezes when I click start
TMPGenc doesn't like ac3 audio which your file has .
Files with ac3 need to be handled in a certain way have a look at this guide , it may help.
https://www.videohelp.com/forum/userguides/186739.php -
Let it be known, Andyp1 was right and I was wrong.In my post, I stated that it freezes when I click start
_________________
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
