Well, as has now been established, DVD-Lab apparently does a thoroughly poor job when it comes to I-frames and chapters (and subtitles, incidentally). But it seems to me... that chapter information is probably only the tiniest bit of data in the whole DVD. As long as the information is not integrated with the rest of the DVD's data in some needlessly irreversible fashion, I have to suspect that it should be possible to change chapter information after the DVD is created.
Naturally, this should only work if the new timings land on I-frames. But that's about all I can say with any degree of certainty. Point is, I force my mpeg2 encoder to create I-frames at specific spots. I try to tell DVD-Lab where I want chapters, but it only approximates. And then it spits out something even less accurate - sometimes by a full second or two. The chapters are worthless! I need to get that fixed.
Hi Colmino,
Check out IfoEdit - I've not used it for changing the chapter timings, but would guess it's possible as it's a powerful tool. "How?" is a different question that I can't answer.
Hopefully someone else can...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
ifo edit will change your chapter points dont know how exactly because i only use it for authoring, but it will require a text file with the frame where you want your chapter point. The way I create them (for authoring) is that I multiply the framerate of the movie times the number of seconds where you want the chapter placed. that is if you want the second chapter at 10 minutes use
chapter point = frateX10minx60
the text file must be a column of these positions the following is a general file I use for positions every ten minutes in a 29.97 fps NTSC file (starts from chapter two since chapter one is fixed at start of movie).
17982
35964
53946
71928
89910
107892
125874
143856
161838
179820
197802
215784
233766
251748
269730
287712
305694
323676
341658
359640
377622
395604
413586 -
... or try TMPGEnc DVD Author ! put chapters where you want them ! without calculating :P very easy to use ...also great for creating menus !
...check out : http://www.dvd-guides.com/guides.php?category=dvdauthor&name=tmpegencdvdauthor
Best method for splitting up an .avi into various chapters and burning
By aple in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2011, 21:24 -
Need Help Altering Company Video CD for Salesman
By jbmail in forum Video Streaming DownloadingReplies: 5Last Post: 30th Apr 2010, 01:08 -
Altering a picture..
By ray316 in forum Off topicReplies: 13Last Post: 24th Nov 2008, 03:22 -
Altering a voice, what can be done?
By Rudyard in forum AudioReplies: 1Last Post: 10th Jul 2007, 02:33 -
Can chapters created in Nero 6 show up in menu?
By wayney in forum Authoring (DVD)Replies: 2Last Post: 15th Jun 2007, 12:46
