Hi dudes...
can anyone tell me how i can join 3 mpegs together to make a single a dvd... when i join the files using tempgenc it fucks up.
In total all 3 mpg's amount up to 2 hrs, when i join the movies together then test it, the movie plays fine for 20 secs then jumps about 1 hr into the film.
i also used premier pro, but in the end the file was 8 gig! PLEASE can anyone help this dying man!!!![]()
Instead of joining them you can author them together as individual tracks on your DVD. You'll get a slight pause when it switches between tracks, but it's better than what you got now.
"Art is making something out of nothing and selling it." - Frank Zappa -
The easiest way to accomplish this is by using Womble Mpeg-VCR.
www.afterdawn.com/guides/ archive/womble_mpeg_join_tutorial.cfm
How do I solve this file joining problem?
By A_Shepherd in forum EditingReplies: 30Last Post: 2nd Sep 2010, 13:27 -
best softwareto burn raw mpgs with out haveing to rencodeing the video file
By mike300 in forum Authoring (DVD)Replies: 5Last Post: 22nd Aug 2010, 09:28 -
Tmpgnc doesn't work
By better life in forum Authoring (VCD/SVCD)Replies: 3Last Post: 27th Nov 2008, 21:29 -
ASFBIN and Movica : Batch File Joining Possible ?
By Alterego in forum EditingReplies: 0Last Post: 12th Oct 2007, 03:18 -
Quick Question re: Joining mpgs
By boing in forum Newbie / General discussionsReplies: 10Last Post: 19th May 2007, 13:35
