Ok, I have an older laptop computer that has only a 6.4 gig hard drive in it. The only purpose this pc now serves is to keep the baby happy when we're traveling.
This pc has a dvd rom drive in it, but it's frustrating driving down the road trying to swap out the dvd's.
so, what I would like to do is rip 2 or 3 or those dvd's which I own and fix them to where they will fit on that small hard drive and the baby can just watch the movies off of the hard drive instead. I would like to keep as much quality as possible. This laptop has a 15" screen and usually we keep the video on full screen.
Any suggestions on how to do this and keep it away from svcd or vcd?
dvdshrink creates multiple files and doesn't compress enough for me to get server movies on that small of a space.
Thanks!
you'd probably be better off converting the dvds to divx or xvid
member since 1843 -
After ripping your DVD, use Virtual Dub mod to load the video, and use a codec like DivX to save to the hard drive.
Hello. -
Download the movie off Bit Torrent... JUST KIDDING.Originally Posted by darkcyber
Just encode the movie into Divx. Rip with DVDShrink or DVD Decryptor to your hard drive, then follow one of the guides to turn your VOBs into lower bitrate MPEGs or divX or other AVIs. I tried looking for an appropraite guide but could not find one. There are so many, hopefully you will have better luck. -
I would try the program Fair Use. Its in thr useful software section. I dont have a dvd player at work and I convert all of my dvds to xvid using this program. Love the results and ease of use. Hope this helps.
Thanks will give it a shot!
Are there any certain programs that are better for encoding with divx? -
maybe not "better"...but I've had great success encoding DVDs to Divx with DVDx 2.2, using this guide:Originally Posted by darkcyber
http://www.dvd-guides.com/guides.php?category=dvdrip&name=divx5
quality of resulting files is very good...
takes a while to complete the process, but the outcome is very much acceptable...just a thought
mastersmurfie
Suggestions for VHS to Hard Drive Capture and Storage
By hobbster in forum Capturing and VCRReplies: 6Last Post: 27th May 2011, 15:20 -
Help please-cannot playback dvd recorder hard drive recordings ?
By patman67 in forum Newbie / General discussionsReplies: 1Last Post: 17th Aug 2010, 16:13 -
Ripping my dvd's to external hard drive......
By nodollas in forum DVD RippingReplies: 11Last Post: 30th Jan 2010, 11:57 -
Suggestions on how to record live video to hard drive
By bnchs in forum Video Streaming DownloadingReplies: 5Last Post: 29th Aug 2009, 13:38 -
ripping PAL Region 2 dvd to hard drive
By pattirose in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2008, 02:30
