  1. Banned
    Dec 2003
    Whenever I try to install a codec I get this error
    error opening file for wrighting:
    "C:\Windows\System32\ffdshow.ax"
    I also get the same error messege whenever I try to install any audio/video-xvid/divx codec
    what do I do to resolve this problem?
    Dec 2002
    My Swamp
    I would first of all uninstall ffdshow , it actually gave me more problems than it resolved.
    Do it in Add/Remove Programmes
    Then try installing your codecs.
    If you need ffdshow you can easily reinstall it afterwards if you find you need it.
