i have a movie that is pretty good quality svcd (3 disks), can i put them on a dvdr and be able to play them on m standalone dvd player.
dvd player plays vcd svcd dvd and cd audio
thanks
tim
Yes. Dvdlab will author them easily.
If you find that they're just slightly too large, you can also crop the credits from the end in dvdlab.
There is other authoring software that can do it, but I don't think they offer the flexibility of dvdlab.Cheers, Jim
My DVDLab Guides -
Have a look here SVCD2DVD and SVCD2DVDMPEG
https://www.videohelp.com/tools?toolsearch=svcd2dvd&s=&orderby=Name&convert=&dvdauthorfeatures= -
Got to the green "all guides" section, click on format conversion, select SVCD to DVD. Lots of good guides.
An SVCD on DVD is not in spec for DVD because of the 480x480 resolution. You can try one and see if it works on your machine. For maximum compatibility you will need to re-encode, 352x480 is best.."Art is making something out of nothing and selling it." - Frank Zappa
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
Out put from avi files
By santolina in forum EditingReplies: 4Last Post: 20th Sep 2009, 11:51 -
Question how to put several dvds on one DVDr
By jimdagys in forum Authoring (DVD)Replies: 7Last Post: 24th Nov 2008, 10:29 -
Can I Put Video Files And Picture Files On Same Disc?
By Lennoxtown in forum Video ConversionReplies: 3Last Post: 29th Dec 2007, 06:05 -
where to put the MAQ files
By the posse in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 10:52
