Hi,
I have several hours of video in VCD-ready MPEG-1 format. Does anyone know if it's possible to burn VCD bin/cue files to a DVD-R and have it work in a set DVD player? Or do DVD players normally look for the video format to match the media format? My thinking is that if a CD-R can hold 75 minutes of VCD video, then a DVD-R should hold about 9 hours.
Thanks,
dew321
you can do it with a little work. you can get around 7 hours worth of video on a dvdr.
if you do a search on the topic, the procedures have been discussed here.
Good luck -
my website will walk you through the process.
Choose the SVCD to DVD because in all reality its the same process for VCD to DVD
good luck! -
Hey Galactica,
here is way to get mpegs from a vcd to simplify steps 1 and 2 from your tutorial.
1. Open Toast 6 (the following procedure needs v6)
2. In the Copy tab, make sure toast sees your VCD
3. choose "Disk Info" from the "recorder" menu
4. select the tracks you want and choose "save as"
- them mpegs are extracted!
Of course this is just an alternative that works better form me.
-- sdm -
interesting...... i never knew toast could do that
when i get some time ill add this in
thanks for pointing that out
Putting a DVD in MKV
By branch in forum DVD RippingReplies: 11Last Post: 23rd Feb 2010, 21:59 -
putting all VCD into a HD media player
By jjhung88 in forum Newbie / General discussionsReplies: 3Last Post: 9th Sep 2009, 11:09 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 12:56 -
putting a link to website on vcd menu. Is it possible.
By Mark-It in forum VCDEasy GeneralReplies: 1Last Post: 21st Dec 2007, 23:08 -
Putting two DVD's into one
By Victor Hen in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 11:09
