i have a couple year old computer and the dvd rom that came with it is rated 16x, but when i try to rip a movie with it i usually only get a max of 3 or 4 MB/s- when running dvdshrink, is the slow speed dvdshrink slowing down the dvd-rom while it is dong the compression.
maybe my slower p4 1.3Ghz is causing slower compression rate thus slowing down the dvd rom in the process.
when i ran a test on the dvd rom drive with nero tools, i tested a 4.1 GB data disk and i read at a max of 13x. so im not sure
also i checked the dma settings on my secondary ide channel where my optical drives are located and they are at dma2, my primary channel where my hd's are is at dma 5.
any suggestions to maybe get better dvd rip times ?????
http://www.newegg.com/app/ViewProductDesc.asp?description=27-131-112&depa=1
Very fast DVD5 ripper, decent with DVD9s. The Pioneer DVD-120 is faster with DVD9s, but not available anymore it seems.
Best of Luck,
-Evan-
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 11:07 -
Win7: slow down dvd speed
By themaster1 in forum ComputerReplies: 4Last Post: 1st Jan 2012, 19:03 -
NTSC DVD player that allows you to slow down playback speed?
By eurotimes2 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 31st Aug 2011, 00:46 -
DVD Rom speed problem
By dafoe in forum DVD & Blu-ray WritersReplies: 8Last Post: 26th May 2010, 11:06 -
DVD skipping problem. Slow drive speed.
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Jan 2010, 15:37
