I can specify in tmpgenc the start and ending frames of a big AVI,
but I couldn't find in Mainconcept.
I don't need editing but I just need to encode part of the AVI
Or it is not cater for in Mainconcept ?
thanks
I use Virtualdub mpeg (a mod of virtual dub) and cut out the part of the avi you want. Then I use Mainconcept to encode. Use "direct stream copy" in Vdub for video and audio.
I just tried to encode a AVI (capture by Sclive) to VCd using mainconcept.
I got beep and beep sound from the beginning and on and off throughout the VCD.
but there is no such sound in both source AVI and VCD encoded by tmpgenc.
Did you encounter such problem ? -
Originally Posted by alfredymwong
Trim MP4/H264 video? Want to remove the start and end - how?
By the loc-man in forum MacReplies: 11Last Post: 2nd Nov 2010, 10:12 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48 -
DVDShrink Start/End
By chronic777 in forum Authoring (DVD)Replies: 7Last Post: 22nd Jul 2008, 12:30 -
where is start/end or seek/duration options
By dr.indiflid in forum ffmpegX general discussionReplies: 0Last Post: 18th Mar 2008, 13:20 -
Trim start and end of MPEG2 compliant video.
By mattstan in forum EditingReplies: 5Last Post: 25th Feb 2008, 10:06
