  1. I need to know what i should capture in to get the best quality transfer to dvd. Should I capture in avi or mpeg 2 and what software should i use to author the dvd???
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    depends on your capturing hardware, and what you are capturing.
    are you capturing analog video or dv? are you using a capture card with hardware mpeg-2 encoding, or software encoding?
    for me, since my capture card doesn't do hardware mpeg-2 encoding, I capture to avi format, using either the Huffyuv or PicVideo MJPEG codecs. Then I convert using TMPGenc and BeSweet, and author with DVD Lab.
    most of my authoring is from VHS captures with an Aver EZ DVDMaker capture card.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by housepig
    ...most of my authoring is from VHS captures with an Aver EZ DVDMaker capture card.
    According to his profile, you two have the same card.
  4. Oh gotta change that. Replaced the ez dvd card with Ati All-In-Wonder 9800. I can capture mpeg hybrid part hardware part software or avi i know what tmpgenc is but what is besweet???
  5. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    it's an ac3 encoder (among other things). I capture to avi, strip out the .wav file, and convert to .ac3 before authoring.
    as for the 9800, if you like the quality of the mpeg-2 capture, and you don't need to do excessive editing, by all means, capture to mpeg-2 and save some steps. I capture to avi and encode because that's how I get the quality I want.
    - housepig
    Housepig Records
    out now:
