Strange problem I'm having...
I ripped and demuxed a video from a DVD-R so I could re-author the DVD with menus (I hate those stand-alone "blue-bar" menus...). I did this using DVD Decryptor, so in the resulting filename are the indicators "NTSC" and "4~3", so I'm prety sure I should be fine. In TMPGEnc DVD Author, I don't have a problem. In DVDit PE I don't have a problem. However, I need more control so I fired up ReelDVD and it's telling me it's a PAL video with no aspect ratio. I'd hate to have to re-encode with TMPGEnc because the video is really sharp and re-encoding effects the picture quality. Any suggestions? Is there a way I can tell for sure what the format, aspect ratio, framerate, etc.. are?
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 18:07 -
Video Properties
By shockgolf in forum Newbie / General discussionsReplies: 8Last Post: 5th Feb 2011, 00:59 -
Remove text from file properties
By Pegsitron in forum Newbie / General discussionsReplies: 1Last Post: 2nd Aug 2010, 08:29 -
Change File Properties/Information for Video Files
By MrRedPants in forum EditingReplies: 5Last Post: 17th Jun 2010, 00:33 -
The Summary tab on a Windows XP video file Properties page is missing!
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 18th Oct 2008, 23:11
