Hello
I have a movie that is on two sides. I want to do so it will be on one side and still keep the menu from side A (side B dosnt have any menu). I was going to try DVDRemake but i dont have money (yet) to buy the full version. Can anyone help me out to fix this so that i can have the movie on one disc (not so hard i think i can do this w/ Shrink) and still have the menus from Side A. I want to use freeware tools for this and dont want to recreate the menus in any author application.
Plz Help
USiT
TOOLS:
1) Get DVD Shrink(free)
2) Get DVD-lab version 1.4 beta 2 or above(30 day full function free trial)
PROCESS:
1) Rip/transcode each side of your DVD to a folder(one folder for each side)
2) Import the whole DVD from the folders into DVD-lab into their own VTS. Folder from side A is one VTS, folder from side B is the other VTS. There is a guide for doing multiple VTS on www.mediachance.com, check it out.
3) Create the VMG menu that will point to each movie.
4) Compile project and burn to disc.
This is a little over simplified, but I'm at work and don't have the time to write up a step by step. I might create a guide for doing this later.[/u] -
Yes, that is a limitation.Originally Posted by USiT
Other then that DvdReMake Pro should be an ideal tool for this task. Simply copy VTS from side B and paste it to disk on side A. You can even add a "secret" button to one of the menus to play the added material. Or, if you can create a new menu (there are some free apps to do this), you can insert it and have a nice link to inserted stuff.
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
FREEWARE for batch, menu-less authoring of DVDs
By nharikrishna in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2011, 04:00 -
DVDs with menu will hang
By John B. in forum DVD & Blu-ray PlayersReplies: 6Last Post: 3rd Jan 2009, 10:55 -
edit language menu in DVDs
By hellbound in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 04:51 -
create menu for DVDs usin photo shop
By hellbound in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 04:34 -
how to make a dvd from 2 or more different dvds with menu and subs??
By vinayak1986 in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2007, 01:59
