I was asking about this in a different thread, but it more belongs here.
Anyway: I want to take my .AVS script and encode the audio as .AC3, without creating any temp files.
Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
I had a thought; can I use VirtualDub to convert the audio to a seperate .AC3 seems like all the AC3 codecs are just for reading and not creating.
Ejoc's CVD Page:
DVD:
Capture:
There was work on a ffmpeg binary that would allow an avisynth script as the input, but from what i recall, it was video only. There was also talk at one time of allowing besweet to input from an avs sctipt, but i don't believe anything came from that.
Alternatively, what i use is a small binary called avs2wav.exe that i have set up in my shell. All i have to do is to right click on my script, then click 'avs2wav'. I then take that intermittent file, and create the ac3 stream with ffmpeg. Such a process could probably be automated from a simple batch file that could be called using an argument from the command line.
AVS2WAV can be found here: http://webjory.tripod.com/avisynth/avs2wav.htm
Swift avs help
By jerome224 in forum Newbie / General discussionsReplies: 4Last Post: 20th Jun 2011, 19:27 -
how do i take avs logo off avs video
By tnwolf35 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2010, 21:08 -
AVS Video Converter and True-HD Audio (AC3+) issue
By lionelblair in forum Blu-ray RippingReplies: 3Last Post: 18th Sep 2009, 06:36 -
how to use TempGaussMC_beta1.avs ?
By 3thman in forum Video ConversionReplies: 7Last Post: 15th Sep 2009, 00:08 -
avs wrap.
By dammit32 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Dec 2008, 13:29
