I'm trying to re-author Kill Bill (that beast) and I would like to have the subtitles present when ever they are speaking non-english. I am fluent in Meastro as I have authored many DVD's, but I am stumped on this one. Can't find any good tutorials either...
I figure I need to :
1. Strip subtitles from DVD (what is most recommended for this)
2. Add subitles into Maestro
3. Make Maestro play subttles at appropriate time (This blows me away, here's the main problem)
I think I can figure 1 and 2 out (any suggestions would be nice) but #3 that's the killer, any help would be greatly appreciated.
rhuala
just load the english subtitles and force them on (you can do this right at the menu button) .. the english subtitles will only show up when you want them to
not sure I follow you here. Right now my authored version contains only .ac3 and .m2v, where is it Masetro that tells it to force the subtitles on.
"you can do this right at the menu button"
... please elaborate BJ_M...
One other thing I should mention is I have a universal remote and all the buttons are used up (TV, DVD, tuners commands) and I lost my original DVD remote so I can't atually go into an original movie and turn on subtitles... this is kinda why I am trying to rebuild this DVD, so that I don't have to mess with subtitles thru the menus...
Thanks,
rhuala -
when you hit the play button ... you can force subtitles on ...
look in maestro menu tab , under "buttons" -> "stream pre selection"
or for each subtitle entry , you can force it in one by one (double click it) ... theh check box is at the top
its all covered pretty well in the manual ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
"its all covered pretty well in the manual ..."
oh the thing is I don't have the manual, see there was this guy walking down the highway, so I jumped out my car and beat the crap out of him, then noticed he dropped some disks so I picked them, and wow they were DVD Maestro. So then obviously I asked him for the manual but he started kicking me and shouting so I had to run. I also started hearing sirens so I high tailed it... -
I don't know if being fluent with Meastro will help.I am fluent in Meastro as I have authored many DVD's
Meastro and Maestro are two totally different programs. One is for organizing porn collections and the other one is a pro dvd authoring program. -
Originally Posted by rhuala2
the problem then is - you don't have the dongle either ...
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
Pls help with my TV USB video problem - does not support dts and subtitle
By emfung in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2011, 06:52 -
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 14:31 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 11:51 -
DVD cannot be read after written - Pls Help
By its_me in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Jun 2008, 03:25
