I'm not sure exactly what i want to do but i want it too look real professional, as if it was Regular DVD.
I was thinking maybe a clip from a movie then maybe a Flash or GIF animation to introduce the menu. Also can i get it to play a animation when i click on one of the menu choices.
Any advice or software choices would be great, i just want one bad ass startup menu.
<font size=-1>[ This Message was edited by: uknow on 2001-11-13 17:21:46 ]</font>
actually you should be able to load the wav into the encoder without doing anything to it, just load it as the audio part. The encoder will encode both the audio and video into one compliant mpeg (vcd), format.
whoops, your fast tigerwolf.
I moved that question to the Conversion section and replaced it with this menu question.
But thanx, well if what you say is true i wonder why the tutrial told me different.
You can view the tutorial and the post here:
https://www.videohelp.com/phpBB/viewtopic.php?topic=65931&forum=3
HIGH Quality Video
By videohelpnewbie in forum Video Streaming DownloadingReplies: 4Last Post: 13th May 2011, 11:55 -
High Quality VHS - Possible?
By Taffin in forum RestorationReplies: 15Last Post: 16th Dec 2009, 23:32 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
