Hi. I just tried to install DVD2DVDR and I got an error message that said "Install ASPI Driver first" Does anyone know how to fix this? TIA![]()
I haven't used that program but it sounds like you need to install the Adaptec ASPI package. Can find that here: http://www.adaptec.com/worldwide/support/driverdetail.jsp?sess=no&language=English+US&...aspi_471a2.exe
Like a flea circus at a dog show! -
http://aspi.radified.com
Get ForceAspi and install it.Cheers, Jim
My DVDLab Guides -
ASPI is an icky thing, especially under 2K, and SUPER ESPECIALLY under XP. Well, ok it's not really THAT icky, but apparently SOMEONE changed SOMETHING, because Adaptec's "XP 32-bit Install" just doesn't register the ASPI components properly.
And sometimes ForceASPI works, and sometimes it doesn't.
There are a COUPLE different fixes you might need to run, depending on the program you intend to use.
For example, there's a completely separate fix to the ForceASPI fix that has been posted on the Exact Audio Copy forums, which is needed to get EAC and some other Audio programs to see your drives properly.
- Gurm
Is Super known to install any "extras" other than OpenCandy?
By brassplyer in forum Newbie / General discussionsReplies: 61Last Post: 17th Nov 2013, 10:45 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
AVS Video Editor Blu-ray verification slow and "driver package" suggested.
By rjamesd05 in forum Authoring (Blu-ray)Replies: 0Last Post: 26th Mar 2010, 08:01 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 02:16
