There's tons of sites hosting the red vs. blue low resolution DivX episodes. Whenever I try to play them in anything they crash the program, or they'll play for 5 seconds and then the video stops and the audio continues. Help please! VirtualDub says it can't find the DX50 decompressor. If that's DivX 5.xx (5.11) I know I have that.
Taken from a thread from 'duck' at another site:
dx50 is fourcc code for the DivX5.xx codec - you can download the Standard (free) DivX 5.1 codec from here:
http://www.divx.com/divx/
If you had trouble installing it I would suggest that you go to control panel - add and remove programs - and see if it lists an installation
for the DivX Codec - if so I would first remove it and then try a reinstallation.
If it's not listed in add/remove programs then (only if you have had problems with a new installation) in controll panel go to 'system' then click on the hardware tab then click on device manager -- scroll down to sound, video and game controllers and click on the plus then right click on video codecs and click on properties then click on the properties tab of the box that opens and see if you have DivX.dll listed as one of the video codecs - if so then I would highlight it and click on remove --- Once that has been done then you should be able to reinstall the codec from the dl obtained from the site above. -
Ah it worked. All I did was install the DivX codec from DivX (just the codec, not the adware bundle)
Halo: Waypoint - Website - Red vs. Blue - MIA
By Simmons in forum Video Streaming DownloadingReplies: 3Last Post: 20th Nov 2011, 20:24 -
VHS capture : red/blue lines
By pastapesto in forum Capturing and VCRReplies: 0Last Post: 24th May 2010, 06:32 -
Blue and Red Output
By PowerFalcon in forum Video ConversionReplies: 5Last Post: 22nd Jun 2009, 20:29 -
Bright red, blue?? help...
By waefwaeefwaefw in forum EditingReplies: 3Last Post: 12th Sep 2008, 21:31 -
Doctor Who Indie Music Track - Blue Box - The Red List
By DazJWood in forum Off topicReplies: 0Last Post: 6th Apr 2008, 08:08
