Hi there,
I've made an experience, and burned some MP3 files in a DVD, as I used to do with MP3 CDs. But to my surprise, my TV DVD player fails with a read error... What's wrong? Is it possible to put MP3s in DVD? Thanks in advance,
Cirruz
What DVD player have you got? Some will support MP3 CDs but not MP3 DVDs. On the bar to your left, you'll see a catagory "DVD Players" - lots of information to be had in there. Here's the link to save you a second:
https://www.videohelp.com/dvdplayers
Also, is your DVD player compatible with the DVD media you are using? This could cause a read error.
Failing these two options, could it be as simple as a bad burn? Try burning to a DVD+/-RW and see if it works.
Cobra -
Cobra, thanks for your reply. I have a Mustek v520 DVD player, and it reads my EMTEC DVD-RWs just fine. This only happens with MP3 DVDs. I'll check the first compatibility issue that you posted.
Cirruz -
I've just taken a look, and a reviewer called Mickey said:
You could try e-mailing Mustek for confirmation, but it looks like your player doesn't support it.the player writes NO DISC after putting in some DVD-MP3...
Cobra -
just keep burning them to mp3-CD.
or you could try to split up lots of tunes,by putting them in seperate folders with 20 or so tracks in them.
faling that there are a couple of programmes out there that can put many hours of music on 1 dvd,like audio dvd creator,and dvdaudio+creator. -
RottenFoxBreath's suggestion is a fine one.
You're most welcome!Originally Posted by Cirruz
Cobra
Lame MP3 (or any MP3) in Sony Vegas 7
By boom731209 in forum AudioReplies: 7Last Post: 28th Oct 2010, 17:13 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 05:36 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 13:05 -
how to convert MP3 vbr to MP3 cbr?
By sumeshkri in forum AudioReplies: 2Last Post: 26th Aug 2008, 00:59
