Hi there,
I bought a region 1 DVD and when I play it on my PC, with a NEC ND-2500A, the VIDEO_TS folder is empty. It plays OK in my TV DVD reader. Is this some kind of protection mechanism, or is it something with the NEC drive? Thank's in advance,
Cirruz
something with your explorer
they cant read it if your computer doesn't see it ..
it is not a new protection system
try rebooting with the DVD in the player or something .. or popping in and out a few times or refreshing ...
check properties and see if the size is correct ...
check with DVD Decrypter also as sometimes it will see a disk, i notice, before windows will ..
or possible -- it IS something with your drive -- or not reading UF structure correctly .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
FAVC Video_TS EMPTY! (have working files?)
By RobAdam in forum Newbie / General discussionsReplies: 34Last Post: 11th Jun 2011, 13:28 -
Powerdvd won't play movie with an empty BDJO subfolder in the BDMV folder
By gll99 in forum Software PlayingReplies: 0Last Post: 29th Oct 2009, 21:29 -
sent pm folder remains empty after multiple posts
By auto7890 in forum FeedbackReplies: 1Last Post: 24th Nov 2008, 22:52 -
No Video_TS Folder..
By NatalieR in forum ffmpegX general discussionReplies: 1Last Post: 5th Feb 2008, 10:53 -
AVI2DVD with DVD2SVSD video_ts empty
By borisaro in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 27th Sep 2007, 08:26
