How do I burn more than one .iso image files to a dvd using nero?
Thank you.
extract the image first .. use isobuster or mount with daemon tools
well i assume he wants to burn the contents -- otherwise just burn the iso files ....
if it is a vcd or svcd or something -- then its a different story of course .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I imagine alot of disc wouldn't appreciate being burned as Multisession when they didn't originate that way.
I wouldn't think a VCD / SVCD image would even play if burned because there "Disc-At-Once".
I do remember making a BeOS Personal Edition CD, as multisession with a CDFS as second track instead of BeOS.
I don't think that was dependent on the same values we put on "Windows" CD's.
As far as VTOC (Volume Table Of Contents), (not sure of the correct word to describe it), i always thought they were stored in a different place on the disc in "Disc-At-Once" discs than "Track-At-Once" discs.
Changing aspect ratio of video files in iso so for burning w/ correct a/r
By cinesimon in forum Authoring (DVD)Replies: 6Last Post: 10th May 2011, 02:40 -
burning multiple mp4 files to DVD format
By dvdnewbie64 in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2009, 13:59 -
Burning 1000's of files to multiple dvd's
By lordhutt in forum ComputerReplies: 12Last Post: 14th Dec 2008, 15:45 -
Burning multiple .MDF files to DVD
By henry13 in forum MacReplies: 10Last Post: 26th Jan 2008, 13:01 -
dvd iso/files burning problems
By CommanderZero in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 01:25
