I have just bought a Sony DRU 530A dvd burner and cannot burn a movie. I have nero and still nothing I bought dvd's and stll nothing
it's a home movie that I have
can anyone help![]()
There are many ' How To ' guides on the left.
I suggest read them first.
Articles
- Newbie articles and Video articles.
Author
- These guides describes how to author, make menus, chapters and make the VCD, SVCD, DVD disc structure and also how to burn.
Capture
- These guides describes how to capture analog or digital video.
Convert
- These guides describes how to convert a video to DVD, VCD, SVCD, CVD or AVI,DivX,Xvid, ASF and more.
DVD Rip
- These guides describes how to copy a DVD to DVD±R/W, VCD, SVCD, CVD or DivX, XviD.
Edit
- These guides describes how to edit, cut, join, repair/fix video, subtitling, frameserving and also advanced editing. -
ok i have a avi movie and i also have the program that converts avi to dvd now I have converted the file and i am still having the problem of how to get the movie from the output file to nero
i tried to burn it but it says that i have no audio or video
i'm just really stressed out with this it's driving me nuts
someone please help meeeeeeeeeeee -
Assuming that you converted your file correctly, you can try authoring your dvd using this guide: http://www.doom9.org/index.html?/mpg/nero-dvdburn.htm
Can you play your mpeg? Exactly how did you create it? What does avicodec say about the properties of your mpeg? Test it and find out.
Alternatively you can try authoring with something like Tmpgenc DVD Author, newbie friendly and it has a free trial period. Look it up in the guides section (over there <--) for instructions.
Other than complaining, you've given very few details and it makes it very hard to help. The more detail you provide, the better answers you'll get."Art is making something out of nothing and selling it." - Frank Zappa -
honey7568,
You might want to consider using a different burning software instead of Nero. There has been issues burning DVD with Nero.
As for your comment about "i tried to burn it but it says that i have no audio or video". Are you movie files put into a folder called VIDEO_TS? If not then create a folder (i.e. HOMEMovies) then within the HOMEMovies folder create a folder called VIDEO_TS and create another folder called AUDIO_TS. Put your movie files into the VIDEO_TS folder and do not put any files into the AUDIO_TS folder. See http://www.doom9.org/index.html?/mpg/nero-dvdburn.htm for an example. Now try burning with Nero.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 03:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
