  1. OK, I recently had to reformat my hdd and had to reload svcd. Everytime I try to process my mpegs it just stops. It stops at resampling audio. I wasn't sure what was going on so I tried uninstalling and reinstalling as well as .net with no success. I've also tried other mpgs and it still doesn't work. I checked the log file and this is what it states:
    ******** Ripping BIN images to get mpegs (VCDGear -fix)
    Analysing File: C:\COR\vcd1.mpg
    ++ WARN: packet length beyond buffer (pos = 18 + size = 2306 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    Analysing File: C:\COR\vcd2.mpg
    -->Processing 2 mpeg files
    ############### New MPEG File ###############
    Type: VCD
    Horizontal Res: 352
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    (Total size: 533MB, Duration: 00:00:00, Rate(MB/Min): 245,646.27)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    System.IO.FileNotFoundException: Could not find file "C:\COR\vcd1-0.mp2".
    File name: "C:\COR\vcd1-0.mp2"
    at System.IO.__Error.WinIOError(Int32 errorCode, String str)
    at System.IO.FileInfo.get_Length()
    at _S_VCD2DVDMPG.210ff09a2516b1a7.fbd359f29063c517(2b c216f3ce925842 a01d771a37e7320b)
    at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
    Anyone have any ideas?
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can you try the other demuxer in the options?
