Hey all, before I asked how to convert an SVCD mpeg to a DVD mpeg. SVCD2DVDMPG seems like a great program, I used it, and converted it, but once I play the dvd mpgs, the screen is almost split in half, and it shows like 2 vids at the same time. Maybe it has something to do with the aspects I chose, I dunno. Whats going wrong?![]()
Thx for your time,
Dan
Being that you can't increase quality, and are probably losing quality in the conversion, why not leave it as svcd, and just burn it to dvdr? You could fit almost 3 full movies on one dvdr. Of course, not totally compliant, but most dvd players should be OK with it. If your player will play SVCD, then it will play this.
Use DVDLab to author it.
Your other option may be to completely re-encode the svcd into a dvd mpeg, using something like Mainconcept.
Try reading these:
http://www.dvd-guides.com/guides.php?category=othertodvd&name=tmpegencvcdtodvd
http://www.dvd-guides.com/guides.php?category=othertodvd&name=vcdtodvdCheers, Jim
My DVDLab Guides -
Does happen sometimes and is usually the dvd player thats at fault. Let me guess is it a toshiba ?
Have just done one and it plays fine on my dvd player and on my mates but his sister is complaining it dont work on hers, problem the same as your...Not bothered by small problems...
Spend a night alone with a mosquito
DXVA not playing??????plz help
By ansonjoy in forum Software PlayingReplies: 7Last Post: 9th Dec 2011, 09:35 -
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 20:23 -
How to playback BluRay plz ?
By Cov(enant) in forum Blu-ray RippingReplies: 2Last Post: 16th Sep 2008, 18:44 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12 -
VirtalDub ERROR - plz help
By UmmAddan in forum DVD RippingReplies: 3Last Post: 30th May 2007, 18:52
