    Feb 2002
    Hi gang.
    I'm trying to play dolby digital audio files from this site:
    http://www.sr.se/multikanal/english/e_index.stm
    but the instructions say to burn these onto cd. When I try to do this, all I get is white noise. I've got an Apex 1110W hooked up via the coaxial digital to a DD compatible amplifier. I would try muxing them with a still image, but DVDSP won't recognize them as anything other than stereo WAVs. Does anyone have any ideas?
    Thanks.
  2. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Only DVDSP 3.0 (or later) will recognize DTS audio and use it correctly. Otherwise, VLC can decode those files for you, and play them back, if not be able to save the streams to a different format.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
