I have a DVD with 5 .VOB files. If I drop the TS folder into Toast and try to burn it starts to encode and then trys to write but says there is a problem with the source material.
It plays fine with iDVD but I just can't burn it. If I drop VOB.0 it only shows the menu screen, VOB.1 - VOB.5 are the movie. So if I drop just .VOB. it encodes, and trys to burn but hangs about 75% through.
Any ideas on an app that I might be able to make an .img of this with please?
Results 1 to 9 of 9
what version of Toast? (be specific. 5.1, 5.2.3, 6.0, 6.0.5, like that)
what format are you choosing to burn? video or data?
does your window look like this?
dk -
Thanks for the quick reply. Ok I am running Toast Version 6 Titanium.
I am dropping the .ts folder onto toast under the Video option, then DVD Video, NTSC and Standard Quality it shows as UDF-Bridge.
I did try the way you show once but as you can guess no luck.
I am currently trying by adding the individual .vobs into Sizzle will this work or will it put a menu up each time it loads the next .vob?? -
Try what decay suggested again. Video_ts folders should go under advanced/Data(UDF) section, not the video section.
I have tried this now 3 times and still it doesn't work. 1st time DVD p[layer said invalid disc, 2nd time Bueffer Under run, 3rd time invalid disc.Originally Posted by thoughton
Please, please someone else give me some idea of how to get this to work.
I have burned as a Video (DVD Format) before and it has worked but this just won't burn???
I know have 2 the same and neither will burn. I am using Ritek genuine discs. and I have a Wharfedale DVD . Like I said I can play these fine thru iDVD, but it's not quite the same as on a widescreen TV.
Help please............again!! -
How did you build your VIDEO_TS folder? Did you just name a folder VIDEO_TS and toss the VOBs inside? If so you need to build the folder with an authoring program like sizzle or the authoring tabs of FFMPegX or MPEG2 Works. Then you can drag the folder into your UDF data tab in Toast. If you aren't sure, be sure that DVD Player can play the TS folder from the disk.
why not do this, instead of us trying to guess what you did.......
post a screenshot of what it looks like when you are about to click burn, in toast.
if you dont know how to do that, email the picture to me and ill post it for ya -
First step after launching Toast 6 is to select the type of disc you want to burn. In this case, it's Data. Tick DVD-ROM (UDF) after choosing the Advanced tab. (see my inline pic)
Then choose New Disc (button on bottom left of Toast window) and name it in ALLCAPS whatever you want it to be called. Now choose Add (next to New Disc) and name the folder AUDIO_TS. Next, drag your VIDEO_TS folder from your hard drive onto the window. It should look like my pic.
dk -
HOORAY!!! I DID IT!!
Thanks Guys and Gals,
I finally got it to work. Not exactly sure what I did or didn't do the first few times.
I know I didn't use CAPS for the Disc Name. An dthis time I saved it as an Image first just to be sure.
Once again a big thankyou to all who helped me.
VOB file won't process in VDub
By CursedLemon in forum DVD RippingReplies: 3Last Post: 17th Sep 2009, 17:35 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
Main Move VOB files won't transfer to HD.
By JokerFMJ in forum Newbie / General discussionsReplies: 10Last Post: 8th Mar 2008, 10:14 -
.VOB to PSP-Movie issue. Certain won't convert
By egmadayag in forum MacReplies: 5Last Post: 23rd Oct 2007, 16:14 -
DVD Won't Burn
By wwpranma in forum Video ConversionReplies: 2Last Post: 25th Jun 2007, 04:32
