I used to have similar problems in the past.
Try a couple of things:
1. Get the latest firmware for your burner.
2. Try burning with TMPGEnc DVD author writing tool.
Just download a copy and install it. This tool will allow you to burn your movies during the trial period.
Results 31 to 45 of 45
Originally Posted by RottenFoxBreath
My problem seems to have fixed itself. I went back a version on Nero Ultra Edition, and discs that the player would not read the other day, they now play. I would almost swear my players were female.
Originally Posted by gitreel
I had never encountered compatibility problems with all my DVD players with discs I had burnt using Princo and Ricoh DVD-RW and DVD+RW until I bought a bunch of cheap DigitalMatrix DVD+R (4X) from Meritline. They burn okay at 4X on my DRU500A but did not read on two of my players which was annoying. I tried DVD MF, Nero, TMPGEN DVD Author and Adobe Encore thinking that maybe it was a burning engine problem to no avail. I didn't update my Sony's firmware since I am happy with the Sony's performance to date.
Then I noticed that one disc played fine on a player that would not even recognise it before. Couldn't think how this disc (same media) was burnt differently until I recalled I was burning some shows to disc recently and noticed that the burn rate was 2X (even though the media was 4X). The DVDMF setting was burn max speed yet it burnt at 2X for some reason. When I changed that to burn at 4X it did. But it also made me think perhaps the disc that was readable had been burnt at 2X. So burnt a few others at 2X insteand lo and behold, they seem to read okay.
So one conclusion to be drawn from this, apart from trying different burning engines (I am not sure the actual authoring program makes any different) and possibly upgrading firmware, try burning at a lower speed
As usual YMMV but I think I have solved my problem with compatibility -
Gurm Wrote:
Err... so lemme get this straight - you're burning with Nero? That right there is a problem. Nero can't do DVD Video to save its life.
Burning with Nero is obviously not the problem. You said it yourself that the majority has no problems burning with Nero. So obviously Nero CAN Burn DVD Video "to save its life".
Since there are other products (IMGTool/DVD Decryptor, or Copy2DVD, or even EZ Coaster Creator) with which there are NO people who experience these problems, and since Ahead keeps changing the way Nero burns DVD Video with each new revision (in what one might guess to be an attempt to "fix" this problem), we are forced to come to the conclusion that Nero is less than satisfactory.
If it works for you, great! You're in the majority of users who have no problem at all.
However, if it does NOT work for you, don't be alarmed because you're certainly not alone.Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Originally Posted by CaseyComb
Some versions work and some version don't as for those it works for they either are using a version that works or their DVD player is very forgiving of burning standards.
Any way you slice it using NERO for DVD Video burning is like a crap shoot.
It is NOT reliable.
Working for some but not anywhere even close to all is a joke!
I've been using Nero for DVD burning since 2001. A few hitches in the early days, but I've had zero problems since 2002. Most often, it's ASPI and the OS causing the problems, something not the fault of NERO.
Stick to Nero 5.5.10.20-5.5.10.5x to be safe.
This post went on a long way. I have no idea who needs help with what anymore. I'd bet media/player before anything else.Want my help? Ask here! (not via PM!)
Doesn't it strike you as odd that you insist NERO works fine when you also state that it is best to stick with version # blah blah blah?
Again it just doesn't add up ... NERO is very "buggy" when it comes to DVD Video burning. Having to "stick" to a specific version (which is nowhere near new) shows poor programming etc.
Clearly I side with Fulcilives, here.
It's a simple matter of numbers.
Let's say that you have a type of car, called the Ford Nero.
Now, 80% of people, or even 95% of people, who get in the car... it works fine, drives fine.
But the OTHER 5%... well, when they get in the car, no matter how skilled a driver they are, the car drives off the road and into a tree less than a mile from their destination.
Would YOU get in the car and drive it?
Hell, even if 0.01% of drivers had this problem, Ford would recall the car and be fending off lawsuits for years and years.
The simple fact is that if you run Nero and use it to burn DVD-Video, you are running the risk of making non-compliant video discs. I myself have made several "iffy" Video DVD's with Nero.
And the fact that CERTAIN versions work and OTHERS don't - does NOTHING to make it MORE reliable. It merely serves to illustrate its unreliability. The average user won't keep using an old version, they will upgrade.
- Gurm -
I burn with Nero (6) and DVDMF. For shows I record myself off TV, I almost always author the DVD with DVDMF and then burn with it. On occasions I hae not burnt with DVDMF but just told DVDMF to create the DVD directories and burn with Nero or create and iso image and burn with Nero and it works fine.
When I take backups of my own DVD's (albeit not that often) I invariably burn with Nero since I don't know what other app can do a standaline burn of the video_ts folder.
Apart from problems with playing Digital Matrix DVD+R (4X) discs in certain players (a solution I have detailed elsewhere) I have never had any problems with Nero
My burner is a DRU500A 2.0f firmware
Again I guess YMMV -
There's no way to prove that it wasn't user error...regarding both Ford or Nero. As I have stated before, opinions don't count as fact.Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
I love you Nero supporters.
"It works for me and a lot of other people, so there must not be any problems with it!"
Nero has ISSUES with burning DVD Video. It's a simple fact. I can make it work, but I shouldn't have to fiddle. The DEFAULT settings for DVD Video should be the ones that work for everyone.
Newbies sometimes CAN'T make it work, and that's a problem.
"It's user error!"
What is?
Step 1: Insert blank disc.
Step 2: Take DVD compilation that burns with EVERY OTHER PROGRAM, and hit "burn".
Step 3: Watch as it FAILS TO WORK in a standalone player.
I've done this myself. Identical media, machine, burner, the ONLY difference is that I used Nero instead of Copy2DVD. Nero failed.
That indicates a bit of a bug, don't you think? And dropping back or stepping forward a revision in Nero fixed it... until the NEXT release when it was broken again.
That's not "user error". That's a BUG.
It works for you? Great. Wonderful.
But it doesn't work for everyone, which means that I can't recommend it to newbies, and when they have "mysterious" problems it's a suspect factor. End of story.
This has been hashed out too many times for anyone to take your "it doesn't happen" claims seriously. So go heckle someone else.
- Gurm -
deja vu
the quite funny in parts "Why i don't use Nero ! "
https://www.videohelp.com/forum/viewtopic.php?t=179275
and the Classic "*for all who use nero,and dvd wont play in your stand-alone*"
https://www.videohelp.com/forum/viewtopic.php?t=127624
make some good reading as some posts are real funny
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 00:20 -
stand alone dvd players that play .wmv or h.264
By scorpio291 in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2009, 10:58 -
Problem With Stand alone DVD player and Burned Dvds
By tealmarlin in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2009, 14:02 -
Key 2 getting DVD-/+R/RW’s 2 play on stand alone DVD players/recorders/not
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 11:07 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 06:59
