I am having a problem when ever i try to burn a iso image in DVD Decryper sometime i can burn 1-3 discs with no problem but then like last night happens and i get one disc out and everything almost after that locks up the pc. I tried to do a defragment and that did not really help. Any other ideas????
thanks,
tech
Results 1 to 13 of 13
Take the cover off and see if it helps. Then try your ram, CPU or power supply...swap 'em out if you can.Originally Posted by handyguy"Art is making something out of nothing and selling it." - Frank Zappa
the cover is already off and it is a newer HP. it is a steady 70-74 in here at all times..............
Try another software and see if it works there. Is it in an enclosure? What burner are you using? What media are you using?
Blah, blah, blah -
Also check if you installed any new programs and do you disable your antivirus when burning..
Also, detail you system specs (i.e. Operating System, amount and type of RAM, processor, etc...)
Systemis a hp.
AMD Athlon XP 3200+
512MB RAM
OP SYS on a 80GB HDD
160GB Ultra ATA Maxtor 8MB Buffer
win XP home
bultin HP 300n DVD +R Burner (not often used)
Lite-On EXT 851S -
I would definately try other burning ROMs, and disable all processes and applications that are not required to be running. If that fails, then reseat the IDE cables running from the DVD burner and the hard drives. You may have faulty cables. If all else fails, then replace the cables.
Connect your burner as a slave to your secondary hard drive. Use that hard drive exclusively for your video. That may help.
Good luck. -
well I tried nero 6 but it says a reset has occured anytime i use blank -r media. I am very confused as to what i should do. I am wondering where a good place to do a firmware update on this lite-on 851S is?
Help; Capture Locking Up with Canon Elura 90 DV
By bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 22:37 -
Slow & locking up
By BLSAMPLES in forum ComputerReplies: 7Last Post: 17th May 2010, 14:17 -
Why is DVD Decrypter locking up?
By dphirschler in forum DVD RippingReplies: 11Last Post: 14th Jan 2010, 21:34 -
DVDRW drive cant read DVD Movies - Is it Region Locking or ... ?!?
By quantass in forum DVD & Blu-ray WritersReplies: 7Last Post: 8th Apr 2008, 22:45 -
Subrip2scc locking up?
By Lbrow in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 14:08
