  1. I RECENTLY GOT A BUSLINK DVD BURNER AND SINCE THENI HAVE NOT BEEN ABLE TO PLAY MY MPEG FILES THEY SKIP IN SOUND AND VIDEO DVDJUST TOOK OVER IS THERE ANYWAY I CAN GET MY MPEG VIDEOS TO PLAY AT A NORMAL SPEED
  2. First thing you do is settle down. And second you find out what codecs you obviously have installed since you got the burner - try uninstalling them or reinstalling your old ones.
    Dec 2002
    My Swamp
    If it was recent , then your best option may be to uninstall your burner , restore your pc to a date when everything was ok.
    Make sure your files play ok then reinstall your burner and go from there.
    AND DON'T WRITE EVERYTHING IN CAPITAL LETTERS IT VERY HARD TO READ AND IS CONSIDERED 'SHOUTING' ON A FORUM.
    Feb 2004
    Vermont, USA
    I also have a Buslink, but it is really a Lite-On 451s. As far as I know Buslinks are either Lite-On or NEC. First see if you can establish which yours is & then go to either the Lite-On or NEC web site & download the latest drivers. This may solve your problem.
