WHEN I RECORD A VIDEO ON A CD TAPE AND TURN IT INTO A RM FILE THEN A RAM FILE IT MAKES FOR QUICK DOWNLOAD NO BUFFERING USING REAL PLAYER. WHEN I RECORD A VIDEO ON A DVD TAPE THE QUALITY IS MUCH BETTER BUT WHEN I TURN THAT INTO A RAM FILE IT TAKES TOO LONG TO DOWNLOAD WHAT IS THE PROBLEM HERE AND IT DOES A LOT OF BUFFERING LIKE IT DID IN THE OLD REAL PLAYER SO DIALUPS GET A SLOWER DOWNLOAD MUCH SLOWER IS THERE ANYWAY AROUND THIS THE RECEPTION IS GREAT THE MB S FOR THE NON DVD RAM FILE I S 11 MB AND THE MB S FFOR THE DVD RAM FILE IS 7 MB SHOULDNT IT DOWNLOAD FOR DIALUPS AT THE SAME QUICKNESS BUT THE
NONDVD RAM FILE 11 MB DOWNLOADS QUICKER THAN THE DVD RAM FILE 7 MB SO FAR NOBODY HAS BEEN ABLE TO ANSWER THIS QUESTION
mine too. i cant even understand whats going on due to the lack of punctuation.Aggghhhhhhh, my eyes hurt.
how about you rephrase what you are trying to say. turn off the caps lock key, and use the commas and periods, they are your friends. -
i sorta stopped reading when i saw cd tape ....
but for sure stopped when i saw dvd tape ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I can understand you just dont know the answer. Well here you go i just puncuated correctly Whats the answer
Type in lower case....Originally Posted by JAYDALOSSNot bothered by small problems...
Spend a night alone with a mosquito -
"SO FAR NOBODY HAS BEEN ABLE TO ANSWER THIS QUESTION"
that's because so far nobody has been able to understand the question
i think you should stick to the cd tape since it's faster than the dvd tape.Guns don't kill people, people kill people, guns just make it a lot easier. -
First of all are you referring to a rm file thats has dvd resolution as compared to vcd resolution or just recorded or burned to 2 different types of media with the same resolution?Cd tapes and dvd tapes are sure new to me,can you elaborate on what you really mean?
Video File (Suspected Real Player)
By Keycool1 in forum Video ConversionReplies: 2Last Post: 16th Feb 2011, 21:55 -
no dvd audio in WMP or Real player.........
By tomnat in forum Software PlayingReplies: 4Last Post: 7th Feb 2008, 19:50 -
Real Player Format
By Russo in forum Newbie / General discussionsReplies: 3Last Post: 1st Dec 2007, 00:00 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05 -
Real Player file downloads
By thegoose47 in forum Video ConversionReplies: 2Last Post: 10th Oct 2007, 16:47
