Just ordered first computer with a DVD-ROM and DVD_+ drive/burner. I'm in the U.S. Would like to know if the DVD-ROM will play other regions and PAL. If not how do I get around it. Can external PAL compatible drives be found and added? If brand of computer matters it's a Sony RZ series. I want to back up my R2 PAL dvds to DVD-R that will play in R1 player with DVD Shrink Copy. Also remove unwanted subtitles. Thanks.
Or you could just make sure DVDDecrypter is open first - let DVDDecrypter rip the entire DVD(in file mode) to your HD - then open those files with DVDShrink. The result will be region free.....just did it this morning as a matter of fact.
Replace dvd drive with dvd-rom drive.
By jtrapat1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Dec 2008, 11:33 -
New DVD ROM drive, works but PC warns on boot up
By LWC in forum ComputerReplies: 15Last Post: 24th Dec 2008, 18:19 -
Suggestions for a new, low priced DVD-ROM drive...
By i am x in forum DVD & Blu-ray PlayersReplies: 5Last Post: 15th Mar 2008, 23:03 -
Help on Choosing a DVD-Rom Drive
By scustalow in forum DVD RippingReplies: 1Last Post: 13th Jun 2007, 12:04 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 08:55
