Hi! Heres what Im trying to do. I downloaded some OGM movies from a serie but not all episode have the intro. what I would like to do if possible is to add the intro from one episode who have it to one who doesnt. So far I manage to get two ogm files, the intro, and the episode, I just cant find a way to join them. I only need help about the video part, im good wif the audio and subtitles. Can this be done with virtualdubmod? if not what program can i use? Also, if the 2 files i need to join arent same resolution, can they still be joined or I need to make them the same res, and with what program?
Thanks for help
I would have thought that VirtualDub (standard, not VirtualDubMod) would be able to do this. If you run the files through GSpot it will tell you what's in those files.
In VirtualDub, you open up your first file then go File --> Append segment. Make sure both video and audio are on "Direct stream copy" and save it as AVI once you have finished adding all the segments together.
Failing VirtualDub, you could try any of these tools:
https://www.videohelp.com/tools?toolsearch=join&s=&orderby=Name&convert=&dvdauthorfeatures=
Best of luck,
Cobra
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
Join two or more movies AVI and bitrates
By Jomapil in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2008, 17:20 -
how do I join several movies and add subtitles?
By dannoura in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2008, 17:17
