I have lots of avi files and TMPGEnc will only convert the ones that are compressed with DIVX and not the ones that are compressed with XVID. What do I do.
Results 1 to 20 of 20
Yes it does, provided you have the right codec installed. ffdshow does a good job with XviD...not the ones that are compressed with XVID
/Mats -
I repeat myself...Originally Posted by mats.hogberg
What do you mean by that?Cause I really dont wanna use that program to just decompress it.
/Mats -
Hi
Can you actually play the XviD movie?
If you can't then like mats.hogberg states you need the XviD codec.
The same rules apply for playing a movie using a certain codec apply when converting from that movie to a format using a different codec.
Once a codec is installed it will allow your system as a whole to deal with that codec, not just TmpegEnc, beit play the movie or convert it.
Simple as that. End of story!
Andy.Work you bloody thing.... -
If above doesn't work, this might...
Anyway, reencoding the XviD to DivX is not the solution.
Another possibility is to use the FourCC Changer, and change the info in the AVI from reading XviD to DivX. This fools the decoder into thinking it's a DivX, and the DivX codec happily decodes (some) XviDs as well.
/Mats -
Best way is to frameserve from virtual dub... no need for conversions or ffdshow (yuck!). Works every time.
True - If VirtualDub doesn't have the same problems as TMPGEnc has to read XviD (which it will have you don't have the XviD codec installed). But I've come across not that few AVIs that TMPGEnc refuses to load, while VDub has no complaints what so ever...
/Mats -
Ok now could you please explain yourself fully and provide me with links to whatever codecs your talking about cause I'm not understanding you at all. I can play the XVID movies just fine. Its just that right when I get done with the encoding, it gives me this error. And then when I try to burn the mpeg file to a dvd, no program will accept it. So once again, if your gonna tell me to download a codec then I need a link to it cause I have no clue what your talking about cause I already been have had the XVID codec installed on my pc.
I don't know and I dont feel like checking but what I'm trying to do is convert XVID to DIVX. But no one here has yet to tell me how.
Just use Virtualdub open the XviD Movie and select "Video - Full Procesing Mode" then "Video - Compresion"
Go to File, and select "Save as AVI" -
so you want help but you "don't feel" like checking to see what specific error message underlies your problem......Originally Posted by bigdee
you either have a piss-poor atitude or your communication skills suck
V-dub will convert XVid to DivX, but if you're converting xvid to divx for the purposes of then converting the divx to dvd, you're wasting time and degrading quality.
and you've received several suggestions that were helpful, but you seem disinclined to help yourself
by the way....a google search yields:
"Results 1 - 10 of about 84,800 for converting xvid to divx. (0.40 seconds)"
don't come back till you read them all -
Naw man dont tell me I have a piss poor attitude when I'm just tryin to get some help. Yall keep confusing me cause right when someone tells me the solution someone else goes off and gives me another one. So I'm just tryng to figure out exactly what to do.
Alright lets start all over. So please dont tell me to scroll up or search on google cause I just want a definite answer if thats not too much to ask. So this is how it is, I try to encode the avi file XVID compressed to mpeg. It gives me this error:
Invalid Pointer Operation
What do I do. -
try this....
Google search: Results 1 - 10 of about 23,200,000 for "What do I do?" (0.28 seconds)
http://www.google.com/search?hl=en&lr=&ie=UTF-8&as_qdr=all&q=What+do+I+do%3F -
What does? If it's the encoder, I'm pretty confident the source AVI is somehow corrupt.I try to encode the avi file XVID compressed to mpeg. It gives me this error:
The reason why noone is adressing your q about how to convert Xvid to DivX, is that your XviD related (?) problems will be the same, regardless of what you try to convert it to, may it be mpeg 2 or DivX. The only thing converting one compressed AVI format to another will buy you is loss in quality.
/Mats -
@bigdee
You wrote that people gave you different solutions. It is interesting to know what you tried so far and what are the results?
Convert Divx to Xvid batch
By nick7461 in forum Video ConversionReplies: 8Last Post: 2nd Oct 2021, 12:37 -
How to convert DV to DivX or XviD using Virtualdub
By Baldrick in forum User guidesReplies: 52Last Post: 1st Dec 2011, 18:04 -
Convert DVD into DIVX / XVID using FairUse
By p_uriel in forum Video ConversionReplies: 1Last Post: 19th Jan 2011, 17:26 -
FAST convert to Divx or Xvid
By nerys in forum DVD RippingReplies: 23Last Post: 2nd Oct 2008, 01:30 -
I need to convert dvd into avi!not xvid or divx!
By picky2112 in forum DVD RippingReplies: 5Last Post: 6th Jul 2007, 03:22
