My Panasonic DMR-E85H is setup in an inclosed custom cabinet along with a DirecTivo, Receiver, CD player, and VCR. When I put my hand on top of the E85 it feels hot while the DirecTivo which also has a hard drive fells normal. This is when the unit is turned off. The ambient air temperature inside the cabinet is about 92 degrees. A temperature probe placed on top of the E85 registers about 104 degrees.
Can anyone else with a E85 tell me if there's feels hot? I've heard rumors that some early E85s have died due to excess heat. Mine was manufactured in March 2004. Should I be concerned?
Results 1 to 1 of 1
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
question about PC running hot -room humidity and water coolance system
By mazinz in forum ComputerReplies: 7Last Post: 29th Apr 2009, 18:27 -
Hot shoe pinout
By danno78 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Mar 2009, 12:19 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
More Panasonic DMR E85 problems HELP!!!!!!!
By MOTUfan in forum DVD & Blu-ray RecordersReplies: 16Last Post: 20th May 2007, 19:36
