Hey guys,
I'm loading .avi files into TMPGEnc to be converted to MPEG-2, and during this process when TMPGEnc is analyzing a .avi file that I'm loading into it, it comes up with the message "Buffer Overrun Detected." VFAPIframeserver.exe is the filed mentioned in the overrun. It then goes onto say the overrun has corrupted the program's internal state and it must be closed etc. etc.
Also, the file usually continues to analyze after a few seconds and the warning disappears, but the audio portion of the file will come up blank and it says 'no audio data.' Yet these files all have audio, and are DVD-rips.
Any ideas?? I can't find anything anywhere mentioning this error. Is it something to do with the AC3 compatibility problems with TMPGEnc? I downloaded a fix for that from here but nothing has changed.
Thanks!
Results 1 to 1 of 1
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04 -
Mencoder problem: BUFFER UNDEFLOW at stream 0, raising muxrate to 11088
By fvisagie in forum Video ConversionReplies: 0Last Post: 29th Apr 2009, 17:43 -
issues with wmv for xbox encodes (buffer problem)
By DsOft in forum Video ConversionReplies: 0Last Post: 3rd Dec 2008, 12:52 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 17:08
