Is there anyway to get rid of the jerkiness in the video when converting from pal to ntsc? I used vdub frame serving to convert from 25fps to 23.976fps
If the jerkiness happens during pans, then it's a definite field order problem..This is usually set in the encoder..
Lower Field First
or
Upper Field First
This is the simplest and fastest answer..
It took me 15 bad disks (jerky) to realize that my player didn't like the .AC3 i was pushing out at 300+kbps for the audio..Had to stick to 224kbps.
Help with converting Panasonic Lumix video files NTSC US system to PAL
By bodrilla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Apr 2011, 07:52 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 11:59 -
Video is Jerky after NTSC DVD to PAL VCD Conversion.
By milindb1 in forum Video ConversionReplies: 14Last Post: 10th Sep 2008, 02:22 -
Converting PAL video to NTSC through SUPER
By DJL82 in forum Video ConversionReplies: 14Last Post: 3rd Jan 2008, 04:23 -
Converting PAL ISO to NTSC for DVD-Video
By Nate7410 in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2007, 14:27
