Ever since I started looking into the whole area of DVD Writing and such, and since I bought my DVD Burner (Pioneer 107), one of my interests in getting it was for data backup. AND, cutting down on the number of data CDs that I have and using the superior storage size of DVD-Rs in their place.
However, I can't seem to find any software, like a variation of Roxio's DirectCD or Nero's InCD to be able to just drag and drop files (image files, documents, software, AVis and MPEGs, etc) onto a dvd-r the same way you would onto a cd-r. I've done some searching of the forums and using Google and can't seem to find any information on a subject matter such as this. All the literature concerning DVD-Rs seems to be for movies, but since DVD blanks can store a lot more data than blank CDs, why isn't there any information/software to be able to do this?
Can anyone help?
What burning software came with your dvd-writer?
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
A bird in the hand is worth a foot in the tush-Kelly Bundy
Shocker,
No software came with my burner, it was an OEM Pioneer 107 from SVP.co.uk.
I have the latest version of Nero, but haven't installed it as I have Easy CD Creator 5 installed from previously and to install InCD, it states that you have to remove DirectCD. I will probably install InCD and try it.
Thanks. -
I've hated Easy CD creator since way before they became Roxio and when I found that I'd have to buy a new Adaptec Easy CD creator when I went from '95 to '98.
Nero is a decent all-round CD/DVD burning app.
Data DVDs
By DeathStalker77 in forum Authoring (DVD)Replies: 1Last Post: 28th Feb 2011, 21:08 -
Can't Finalize DVDs from GoVideo VR2940 - But movie data is there
By TGilbert in forum DVD & Blu-ray RecordersReplies: 1Last Post: 22nd Aug 2009, 20:38 -
Dvp5982 reading dvds as data files
By themow in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Mar 2008, 21:52 -
Old dvds data = disapeared. Anything I can do?
By 007craft in forum Off topicReplies: 5Last Post: 4th Oct 2007, 12:38 -
using iffy DVDs for data storage
By blacktooth in forum MediaReplies: 48Last Post: 2nd Jun 2007, 13:45
