  1. Hi...
    first sorry cause my english is not good...
    I bought a Inno 3D Personal Cinema FX5600
    http://www.ivmm.com/inno3d/personal_cinema_fx/fx_5600.html
    and I can't capture TV channels... It works with my DVD and my camcorder (input) and works too with my TV (output) but I can't detect any channel (cable or antenna) with this card...
    I retire the cable and put it direct in the card (Connector for TV cable or Antenna ) and I can't capture anything... just a black window in any software (christv, haupage, intervideo)... any software captures any channel...
    how can I ¿
    Watch, record, and control live TV
    Forget about programming your VCR or dealing with analog tapes. Watch the shows you want, when you want. Record shows, pause live TV, advance frame-by-frame or skip past commercials.
    thanks for atention and I wait for answer
    Cause I forgot some detail about this problem ask me .. thanks again...
    If someones Knows too...
    How can I Test the card to know if the connector of TV Cable (inth card) is working fine...
    any coments can be help me cause I'm newbie in this area..
    thanks again and sorry because my english is so bad !!
    Cheers
    Guinho
    If I understand you right it would seem to me that you can not connect your cable directly to this box. The cable signal has a bunch of different signals together and you need to run this signal through a tuner to select the appropriate channel. You can use your tv or vcr as a tuner.
  3. ooo...
    Tkz Troy...
    but the problem is other...
    I Can connect the cable of cable tv directly in the card (not in the box) that have one connector to input tv cable. I'm a newbie and i don't know wich procedure I have to do, but I Think that i just put the TV cable directly in the card and with the intervideo software tunning the channels...
    I try it with Chris TV too and can't tunnning any channel...
    with the box i can use my camera and tv to capture but i can't watch tv directly by the card without it...
    I want to know to watching tv, I can do it without tv or vcr. If only the card i could do it ¿
    tkz again
    Guinho
