I've read all sorts of guides, I'm trying 2 convert some avi to svcd, the avi look gud but the mpgs have blocks and contour lines, no matter what prog i use or what bitrate, is there some sort of general guide on how 2 get rid of these artifacts? I've read and researched a lot of guides but nothing helps, what can be done 2 improve encode problems like this? thanks
"Just pretend that it's all pretend"
what is the avi source type ?
what encoder are you using ?
what settings exactly have you used ?
can you post a sample image ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How to get rid of these color blocks?
By protoX in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2012, 09:10 -
Converting MKV (Get rid of subtitles)
By kpat99 in forum Video ConversionReplies: 3Last Post: 4th Feb 2012, 08:50 -
:?: Vegas Pro 8.0 - How do I get rid of these "blocks"?
By YouTubeHDHacker in forum EditingReplies: 1Last Post: 6th Dec 2008, 16:19 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41
