Hi. I have a problem with the AC3 audio of my videos. I use premiere to make the final exportation of audio and video, and audio is encoded by the minetonka plugin SURCODE AC3 directly on Premiere. My problem is that, after encoding, AC3 audio volume is a bit low, but anyway, still acceptable. But after compiling it on DVDLAB PRO Beta4 or DVD Producer 4.0, sound is instantly killed. I have to turn the volume up to it's fullest to BARELY UNDERSTAND it. How can I fix this? If I try to normalice audio before ac3 encoding, it saturates and the audio gets corrupted.
Hope you know of a possible solution and can tell me what I'm doing wrong.
C u!
Results 1 to 1 of 1
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 17:59 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
LOAD CLICK AND LOW SOUND at join of 2 avi xvid ac3 using vitualdub
By hawklight in forum EditingReplies: 0Last Post: 15th Jul 2007, 09:44 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 05:46
