    Feb 2002
    Under The Sun
    Hi. Can anyone help me with an MPEG2 (PAL DVD) file I have?
    I basically want to put it on DVD for veiwing through my standalone DVD Player.
    The MPEG2 File was converted from AVI using #1 Video Converter.
    What are the processes of getting it to DVD?
    Thanks in advance.
    TheEverLiving
    "Smell The Flowers Whilst You Can."
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Assuming that your mpeg2 is DVD compliant (resolution, bitrate etc.) then all you need to do is Author and burn. During authoring you can create menus as well. Click on the green "Author" over there <-<-<-. I recommend TMPGEnc DVD Author, it's newbie friendly.
    Edit: Or click on the link that BJM provided.
