Hi, I tried to find a solution to this but nothing I've tried has really helped so far. I'm trying to author a dvd from an mpg that is not dvd compliant as far as resolution goes.
I load the mpg into dvd author and make all the vobs and whatnot and the menus and all look fine when I'm making them. I save the template or whatever and then I close tmpgenc and use dvd patcher to change the first header resolution so that tmpgenc dvd author will go through with making the vob files.
However, when all that is done the right i guess 1/4 to 1/3 of all the chapter thumbnails are green or black, because the resolution is changed to what it's not expecting. How can I fix this? The actual movie plays fine and in the right resolution, but the thumbnails are driving me completely crazy.
You can't. You should be happy you're able to author and play a non standard DVD at all!How can I fix this?
(I'm sure it's possible, but not with TDA and its automatic chapter thumbs.)
/Mats -
weird, you'd think you could just resize the thumbnail or something. maybe that should be a new feature of tda
To accept out of specs and/or corrupt source files? I doubt it...should be a new feature of tda
8)
/Mats -
why not? Should have this option [] I know what I'm doing.
And what about people like me who have dvd players that will play almost any format. Sure I could just burn the files but it's cool to have menus. Sure I could copy the mpg and convert it to dvd standard and then use that for all the animated thumbnails but that's just a pain in the ass
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
