  1. Ok, so I'm ordering a dvd from japan, and what I'd like to be doing is take the region 2 disc, and write/add my own subtitles, then burn it all onto a region 1 disc, where it's exactly the same and only has subtitles added. Is this even going to be possible? Just the r2 -> r1 part I guess. I know subtitles can be made/added.
    thanks
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    When you RIP the DVD to your computer's HDD using DVD Decrypter it will be REGION FREE NTSC format.
    - John "FulciLives" Coleman
    Dec 2002
    My Swamp
    Yes , any DVD you burn will not have a region code. Region codes are only on commercial pressed DVD's.
  4. thanks for the quick replies! and I should be able to rip the japanese r2 with no problem?
  5. Ripping the Region 2 disc to your hard drive will be no problem. Adding the subs will require a bit more effort. Check the guides <---------- or start here:https://www.videohelp.com/forum/viewtopic.php?t=219535
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
