Hi all.
I am attempting to have just an mpeg2 file, ultimately, off of a homemade home video put to dvd. I will later edit and reburn the file to a dvd with a better menu system, so I don't want to just rip and copy the dvd. The home video dvd is a dvd-r made from a stand alone dvd recorder. I will burn to a dvd+r on my home pc.
I have extracted the m2v files that I want using DVD Decryptor. I want to re multiplex the audio and video files with Tmpgenc plus.
There are two m2v files and one audio file. The second m2v file won't merge with the first, as I am told by tmpgenc plus that is it not an mpeg file, while I have no problem with the first file. I can preview each of the m2v files if I just load them in the main menu's video file section of tmpgenc plus. However, if I try to preview them while in the mpeg tools/merge and cut menu, only the first file is playable, and the second is not.
Is there, perhaps, some kind of wrong header information on the second file, or is there something I am missing?
Any ideas?
Thanks in advance.
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 17:08 -
Trying to create DVD from m2v and wav files
By JSLayton in forum Authoring (DVD)Replies: 8Last Post: 28th Jun 2011, 18:56 -
Extracting VOBs To M2V gives me alot of problems.
By Discov3r3d in forum DVD RippingReplies: 5Last Post: 18th Aug 2009, 16:41 -
question about extracting idx/sub files from DVD
By jimdagys in forum SubtitleReplies: 2Last Post: 24th May 2008, 10:49 -
extracting audio from m2v file
By matneaves in forum AudioReplies: 1Last Post: 30th May 2007, 17:56
