Page 2 of 2
FirstFirst 1 2
Results 31 to 34 of 34
  1. Member LSchafroth's Avatar
    Dec 2002
    Originally Posted by FulciLives
    PICVideo MJPEG should be set at "2 fields if more than 240 lines" if you are capturing at Full D1 or Half D1 resolution (in other words a capture height of 480).
    This is for NTSC of course.
    - John "FulciLives" Coleman
    I thought about that too. I went to their site and it says to turn it off if your PC can keep up. It is only there for PC's that cannot handle capturing both fields.
    I turned it off and noticed a huge difference in video quality.
    LS
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    LS
    I couldn't find this information on thier website.
    Can you provide a link to it?
  3. Member LSchafroth's Avatar
    Dec 2002
    OK, I must have been smoking soemthing. I cannot find where I found it. Mayeb it was in the HELP file that comes with the codec. I'm at work so I cannot search my history or the help file. Some of the sites I look at get web sensed here at work. I'll look when I get home.
    LS
  4. Member LSchafroth's Avatar
    Dec 2002
    I just tried CCE, MC and TMPGEnc with the new PicVideo capture settings. I have removed the "if more then 2 lines" setting and the results are terrific on the TV.
    Now I just have to decide which encoder to stick with.
    LS
