ive just edited a dvd ready for authoring, it has two programmes on it , one ntsc and the other pal, tmpeg authour wont let me do it, so before i spend another 20 hours reconverting my PAL DV to NTSC mpeg 2 in tmpgnc is there a program that will convert pal mpeg2 to ntsc or vica versa![]()
canopus procoder or main concept both will ...
either way -- you will have to re-encode except in one case
if it is pal film progressive -- you can re-write the mpeg headers to 23.976 progressive and add pulldown ..
but you will need to resync the audio ...
procoder2 (better than 1.5 by far) does one of the best jobs i have ever seen at ntsc/pal conversions ... including the audio from ac3 or dts"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
NTSC MPEG2 file to PAL M DVD
By Ed2009 in forum DVD RippingReplies: 2Last Post: 27th Sep 2009, 23:05 -
MPEG2 files - are they just MPEG, or are they either PAL or NTSC?
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2009, 15:07 -
convert hd pal mpeg2 file to hd ntsc mpeg2 file
By gearo in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 5th Jun 2008, 01:12 -
converting hd pal mpeg2 to hd ntsc mpegs
By gearo in forum DVD RippingReplies: 1Last Post: 3rd Nov 2007, 18:26 -
NTSC mpeg2 to pal needed
By Caned_and_Able in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 21:13
